26.600
I just applied for subscription and i was wondering if i can use the WiFree until i get connected since i have to wait some days until this happens. It would be good to have internet until then...
Is that possible somehow?
When you activate wifree (EAP) on your subscrition it can take 24 hours untill it is ready for use.
There is no other way unless you can 'borrow' a login that already has access to wifree or public places with wi-fi you can use.
yeah but i dont see any option to activate it at "my telenet". Whichi believe is because i havent linked my telenet services which requires a bill refernce number?
Normally you can use the internet login (a123456 or aa12345) and passowrd to access my telenet.
Then you will see your products and can activate or deactivate services.
