27.153
Hello,
Since schools are closed we want to setup a Minecraft server for my partners' siblings who are in another city.
These are my settings in advanced settings of my router page, port 25565 for Minecraft. The bottom one I didn't touch:
Based on these numbers:
Yet when I check if ports are open online they all say they are closed:
I tried rebooting my router and same result.
I previously also added exception rule for Minecraft 25565 port in my firewall for inbound and outbound rules for both TCP and UDP.
Any idea where I went wrong? I called Telenet but they said it is some setting I have wrong on my end that they can't help with.
Thanks in advance
It seems the photos aren't loading, here are all on imgur album: https://imgur.com/a/EgIa2c3
@Wouter5 Die minecraft toestand staat dat op een windows PC? Stomme vraag misschien want ik ken niets van minecraft. Maar als het op een PC staat moet je vermoedelijk in windows defender ook die poorten open zetten. Want als er niets kan antwoorden zullen uw poorten ook als gesloten staan. Ik zie ook 2 verschillende interne IPadressen staat die minecraft op 2 toestellen?
Yes I made 2 rules for inbound and outbound, as in this video at 7:30: https://www.youtube.com/watch?v=57kEsvcz_Cc
In windows defender I made 4 rules total:
Inbound 25565 TCP
Inbound 25565 UDP
Outbound 25565 TCP
Outbound 25565 UDP
I don't know what you mean by two internal IP's? We have two PCs at home but Minecraft is only on my PC.
Yes I clicked it,
https://i.imgur.com/4kAItHs.png
But the save button is still visible in bottom left when I go back into settings. Is that the delay you speak of? Is it on Telenet's side? The port settings I added are still there in the options.
Could I have done some conflicting numbers in these settings? It feels there should be a simple mistake somewhere.
Do I turn Firewall-bescherming off? Could this be the issue?
(I read somewhere on this forum to try and change the 25565-25566 range to a single port. And from Beide to only TCP, but it is still not working)
@Wouter5 Als je daar op klikt zou normaal gezien het ganse scherm moeten verdwijnen. En krijg je de boodschap dat het weg geschreven is. Soms is de positie niet goed om erop te klikken.
I have clicked it and changes are saved. I have done it many times yesterday and today: https://i.imgur.com/4kAItHs.png
@Wouter5 Dit zou het moeten doen. Nu een vragen aan je medespelers of ze kunnen verbinding maken naar je publiek IPadres:poortnummer. Of thuis eens proberen via het mobiel netwerk, niet via je eigen wifi. En heb je in de instellingen van het spel gecheckt of dit wel de juiste poort is?
Wel, ik heb in de winter een minecraft server opgezet, en die port forwarding zo ingesteld en alles werkte heel goed. Nu proberen we een paar maand later opnieuw zonder aanpassingen en de interne server is niet meer bereikbaar. Ik zou totaal niet weten wat er nu aangepast zou zijn, behalve stiekem een firmware upgrade waar bugs ingeslopen zijn (of meer richting Telenet?). Computer volledig in DMZ zetten, gaan we niet doen, alhoewel het aanlokkelijk is.
@icyjamie Mijn eerste gedachte is... Klopt het ingestelde IPadres nog? Het is aangeraden op een vast IP adres in te stellen op de PC waar die server draait. Iets tussen 192.168.0.10 en 99, zolang je maar uit de DHCP range van Telenet blijft.
Ja, vast ingesteld. Niets veranderd, behalve die server een tijdje niet meer opgestart. Netjes ook het juiste publieke adres gebruikt
@icyjamie Zijn er toevallig updates gebeurd op de computer waar die server op draait? Want dan kunnen eventueel ook die firewall instellingen gewijzigd zijn. Kan je intern nog naar die server? Publieke IP adres is ook nog correct?
Ik probeer mee te denken waar het zou kunnen zitten. Probeer alvast eens met je modem/router een 5-tal minuten zonder stroom te zetten.
Geen updates, firewall regels waren de vorige keer niet nodig, die toch voor de zekerheid toegevoegd. Ook firewall volledig uitgezet. Lokaal wel toegankelijk.
ook geen klachten van andere port forwardings voor andere games, die ook nodig waren.
modem is wel recent gezet zodat hogere snelheden mogelijk waren (abo upgrade)
Gebruik je wel het juiste externe IP adres? Het is vreemd dat de test voor port 15999 ook niet werkt, terwijl dit naar een andere interne PC geforward wordt. Of stand die uit?
Ik neem aan dat dit voor een ander doel is. Werkt dat nog wel?
Misschien even heel kort je PC firewall uitschakelen, gewoon als test?
