Cem
En we zijn vertrokken!
Weak mobile network coverage
Hi, we newly switched to telenet mobile. All family members suffer from weak or no mobile connection in random places. Meaning in some places connection is good, in some others very weak or even unavailable. Locations in and around leuven, herent, bertem.
Even if we have a good mobile connection internet is slow most of the time. I read the faq and check that our settings are correct, eg auto select network.
We came from orange and never had such bad experience.
Is there anything else we shall check or do before going back to orange?
2 reacties
Indeed, Orange has the best coverage between Herent and Bertem.
You can check yourself at https://www.bipt-data.be/en/projects/atlas/mobile
@Cem same problem in Grimbergen. I hope it will improve in the future as I hear more and more complaints.
