ArthurJ
On a roll... Dat loopt vlotjes. Jij bent af! Handje vol!
Redirect naar telegate.telenet.be/.... Java Stack Trace
Sinds zaterdag heb ik een nieuwe modem( DOCSIS 3.1 WIRELESS (DOCSIS) ). Nu kan ik enkele sites niet zomaar meer bezoeken.
Als ik bijvoorbeeld naar bol.com (ingegeven in de adresbalk) ga dan kom ik deze site:
https://telegate.telenet.be/telegate/dynamic/fup_redirect.html?referer=http%3A%2F%2Fbol%2Ecom%2F&red...
Met als inhoud:
Spoiler
FreeMarker template error (DEBUG mode; use RETHROW in production!): The following has evaluated to null or missing: ==> salesOffering.primaryOffer [in template "warning.ftl" at line 7, column 25] ---- Tip: It's the step after the last dot that caused this error, not those before it. ---- Tip: If the failing expression is known to be legally refer to something that's sometimes null or missing, either specify a default value like myOptionalVar!myDefault, or use <#if myOptionalVar??>when-present<#else>when-missing. (These only cover the last step of the expression; to cover the whole expression, use parenthesis: (myOptionalVar.foo)!myDefault, (myOptionalVar.foo)?? ---- ---- FTL stack trace ("~" means nesting-related): - Failed at: #assign primaryOffer = salesOffering... [in template "warning.ftl" at line 7, column 1] ---- Java stack trace (for programmers): ---- freemarker.core.InvalidReferenceException: [... Exception message was already printed; see it above ...] at freemarker.core.InvalidReferenceException.getInstance(InvalidReferenceException.java:134) at freemarker.core.Assignment.accept(Assignment.java:139) at freemarker.core.Environment.visit(Environment.java:326) at freemarker.core.Environment.visit(Environment.java:332) at freemarker.core.Environment.process(Environment.java:305) at freemarker.template.Template.process(Template.java:378) at org.springframework.web.servlet.view.freemarker.FreeMarkerView.processTemplate(FreeMarkerView.java:367) at org.springframework.web.servlet.view.freemarker.FreeMarkerView.doRender(FreeMarkerView.java:284) at org.springframework.web.servlet.view.freemarker.FreeMarkerView.renderMergedTemplateModel(FreeMarkerView.java:234) at org.springframework.web.servlet.view.AbstractTemplateView.renderMergedOutputModel(AbstractTemplateView.java:167) at org.springframework.web.servlet.view.AbstractView.render(AbstractView.java:303) at org.springframework.web.servlet.DispatcherServlet.render(DispatcherServlet.java:1286) at org.springframework.web.servlet.DispatcherServlet.processDispatchResult(DispatcherServlet.java:1041) at org.springframework.web.servlet.DispatcherServlet.doDispatch(DispatcherServlet.java:984) at org.springframework.web.servlet.DispatcherServlet.doService(DispatcherServlet.java:901) at org.springframework.web.servlet.FrameworkServlet.processRequest(FrameworkServlet.java:970) at org.springframework.web.servlet.FrameworkServlet.doGet(FrameworkServlet.java:861) at javax.servlet.http.HttpServlet.service(HttpServlet.java:687) at org.springframework.web.servlet.FrameworkServlet.service(FrameworkServlet.java:846) at javax.servlet.http.HttpServlet.service(HttpServlet.java:790) at io.undertow.servlet.handlers.ServletHandler.handleRequest(ServletHandler.java:85) at io.undertow.servlet.handlers.FilterHandler$FilterChainImpl.doFilter(FilterHandler.java:129) at org.springframework.web.filter.CharacterEncodingFilter.doFilterInternal(CharacterEncodingFilter.java:197) at org.springframework.web.filter.OncePerRequestFilter.doFilter(OncePerRequestFilter.java:107) at io.undertow.servlet.core.ManagedFilter.doFilter(ManagedFilter.java:61) at io.undertow.servlet.handlers.FilterHandler$FilterChainImpl.doFilter(FilterHandler.java:131) at be.telenet.telegate.web.filter.StaticFilter.doFilter(StaticFilter.java:78) at be.telenet.telegate.web.filter.StaticFilter.doFilter(StaticFilter.java:67) at org.springframework.web.filter.DelegatingFilterProxy.invokeDelegate(DelegatingFilterProxy.java:346) at org.springframework.web.filter.DelegatingFilterProxy.doFilter(DelegatingFilterProxy.java:262) at io.undertow.servlet.core.ManagedFilter.doFilter(ManagedFilter.java:61) at io.undertow.servlet.handlers.FilterHandler$FilterChainImpl.doFilter(FilterHandler.java:131) at be.telenet.telegate.web.filter.JavascriptForwardFilter.doFilter(JavascriptForwardFilter.java:40) at org.springframework.web.filter.DelegatingFilterProxy.invokeDelegate(DelegatingFilterProxy.java:346) at org.springframework.web.filter.DelegatingFilterProxy.doFilter(DelegatingFilterProxy.java:262) at io.undertow.servlet.core.ManagedFilter.doFilter(ManagedFilter.java:61) at io.undertow.servlet.handlers.FilterHandler$FilterChainImpl.doFilter(FilterHandler.java:131) at org.springframework.security.web.FilterChainProxy$VirtualFilterChain.doFilter(FilterChainProxy.java:317) at org.springframework.security.web.access.intercept.FilterSecurityInterceptor.invoke(FilterSecurityInterceptor.java:127) at org.springframework.security.web.access.intercept.FilterSecurityInterceptor.doFilter(FilterSecurityInterceptor.java:91) at org.springframework.security.web.FilterChainProxy$VirtualFilterChain.doFilter(FilterChainProxy.java:331) at org.springframework.security.web.access.ExceptionTranslationFilter.doFilter(ExceptionTranslationFilter.java:114) at org.springframework.security.web.FilterChainProxy$VirtualFilterChain.doFilter(FilterChainProxy.java:331) at org.springframework.security.web.session.SessionManagementFilter.doFilter(SessionManagementFilter.java:137) at org.springframework.security.web.FilterChainProxy$VirtualFilterChain.doFilter(FilterChainProxy.java:331) at org.springframework.security.web.authentication.AnonymousAuthenticationFilter.doFilter(AnonymousAuthenticationFilter.java:111) at org.springframework.security.web.FilterChainProxy$VirtualFilterChain.doFilter(FilterChainProxy.java:331) at org.springframework.security.web.servletapi.SecurityContextHolderAwareRequestFilter.doFilter(SecurityContextHolderAwareRequestFilter.java:170) at org.springframework.security.web.FilterChainProxy$VirtualFilterChain.doFilter(FilterChainProxy.java:331) at org.springframework.security.web.savedrequest.RequestCacheAwareFilter.doFilter(RequestCacheAwareFilter.java:63) at org.springframework.security.web.FilterChainProxy$VirtualFilterChain.doFilter(FilterChainProxy.java:331) at org.springframework.security.web.authentication.ui.DefaultLoginPageGeneratingFilter.doFilter(DefaultLoginPageGeneratingFilter.java:177) at org.springframework.security.web.FilterChainProxy$VirtualFilterChain.doFilter(FilterChainProxy.java:331) at org.springframework.security.web.authentication.AbstractAuthenticationProcessingFilter.doFilter(AbstractAuthenticationProcessingFilter.java:200) at org.springframework.security.web.FilterChainProxy$VirtualFilterChain.doFilter(FilterChainProxy.java:331) at org.springframework.security.web.csrf.CsrfFilter.doFilterInternal(CsrfFilter.java:100) at org.springframework.web.filter.OncePerRequestFilter.doFilter(OncePerRequestFilter.java:107) at org.springframework.security.web.FilterChainProxy$VirtualFilterChain.doFilter(FilterChainProxy.java:331) at org.springframework.security.web.header.HeaderWriterFilter.doFilterInternal(HeaderWriterFilter.java:64) at org.springframework.web.filter.OncePerRequestFilter.doFilter(OncePerRequestFilter.java:107) at org.springframework.security.web.FilterChainProxy$VirtualFilterChain.doFilter(FilterChainProxy.java:331) at org.springframework.security.web.context.request.async.WebAsyncManagerIntegrationFilter.doFilterInternal(WebAsyncManagerIntegrationFilter.java:56) at org.springframework.web.filter.OncePerRequestFilter.doFilter(OncePerRequestFilter.java:107) at org.springframework.security.web.FilterChainProxy$VirtualFilterChain.doFilter(FilterChainProxy.java:331) at org.springframework.security.web.context.SecurityContextPersistenceFilter.doFilter(SecurityContextPersistenceFilter.java:105) at org.springframework.security.web.FilterChainProxy$VirtualFilterChain.doFilter(FilterChainProxy.java:331) at org.springframework.security.web.FilterChainProxy.doFilterInternal(FilterChainProxy.java:214) at org.springframework.security.web.FilterChainProxy.doFilter(FilterChainProxy.java:177) at org.springframework.web.filter.DelegatingFilterProxy.invokeDelegate(DelegatingFilterProxy.java:346) at org.springframework.web.filter.DelegatingFilterProxy.doFilter(DelegatingFilterProxy.java:262) at io.undertow.servlet.core.ManagedFilter.doFilter(ManagedFilter.java:61) at io.undertow.servlet.handlers.FilterHandler$FilterChainImpl.doFilter(FilterHandler.java:131) at com.codahale.metrics.servlet.AbstractInstrumentedFilter.doFilter(AbstractInstrumentedFilter.java:97) at be.telenet.mijntelenet.status.api.metrics.MetricsServletFilter.doFilter(MetricsServletFilter.java:38) at io.undertow.servlet.core.ManagedFilter.doFilter(ManagedFilter.java:61) at io.undertow.servlet.handlers.FilterHandler$FilterChainImpl.doFilter(FilterHandler.java:131) at io.undertow.servlet.handlers.FilterHandler.handleRequest(FilterHandler.java:84) at io.undertow.servlet.handlers.security.ServletSecurityRoleHandler.handleRequest(ServletSecurityRoleHandler.java:62) at io.undertow.servlet.handlers.ServletDispatchingHandler.handleRequest(ServletDispatchingHandler.java:36) at org.wildfly.extension.undertow.security.SecurityContextAssociationHandler.handleRequest(SecurityContextAssociationHandler.java:78) at io.undertow.server.handlers.PredicateHandler.handleRequest(PredicateHandler.java:43) at io.undertow.servlet.handlers.security.SSLInformationAssociationHandler.handleRequest(SSLInformationAssociationHandler.java:131) at io.undertow.servlet.handlers.security.ServletAuthenticationCallHandler.handleRequest(ServletAuthenticationCallHandler.java:57) at io.undertow.security.handlers.AbstractConfidentialityHandler.handleRequest(AbstractConfidentialityHandler.java:46) at io.undertow.servlet.handlers.security.ServletConfidentialityConstraintHandler.handleRequest(ServletConfidentialityConstraintHandler.java:64) at io.undertow.security.handlers.AuthenticationMechanismsHandler.handleRequest(AuthenticationMechanismsHandler.java:60) at io.undertow.servlet.handlers.security.CachedAuthenticatedSessionHandler.handleRequest(CachedAuthenticatedSessionHandler.java:77) at io.undertow.security.handlers.NotificationReceiverHandler.handleRequest(NotificationReceiverHandler.java:50) at io.undertow.security.handlers.AbstractSecurityContextAssociationHandler.handleRequest(AbstractSecurityContextAssociationHandler.java:43) at io.undertow.server.handlers.PredicateHandler.handleRequest(PredicateHandler.java:43) at org.wildfly.extension.undertow.security.jacc.JACCContextIdHandler.handleRequest(JACCContextIdHandler.java:61) at io.undertow.server.handlers.PredicateHandler.handleRequest(PredicateHandler.java:43) at io.undertow.server.handlers.PredicateHandler.handleRequest(PredicateHandler.java:43) at io.undertow.servlet.handlers.ServletInitialHandler.handleFirstRequest(ServletInitialHandler.java:292) at io.undertow.servlet.handlers.ServletInitialHandler.access$100(ServletInitialHandler.java:81) at io.undertow.servlet.handlers.ServletInitialHandler$2.call(ServletInitialHandler.java:138) at io.undertow.servlet.handlers.ServletInitialHandler$2.call(ServletInitialHandler.java:135) at io.undertow.servlet.core.ServletRequestContextThreadSetupAction$1.call(ServletRequestContextThreadSetupAction.java:48) at io.undertow.servlet.core.ContextClassLoaderSetupAction$1.call(ContextClassLoaderSetupAction.java:43) at io.undertow.servlet.api.LegacyThreadSetupActionWrapper$1.call(LegacyThreadSetupActionWrapper.java:44) at io.undertow.servlet.api.LegacyThreadSetupActionWrapper$1.call(LegacyThreadSetupActionWrapper.java:44) at io.undertow.servlet.api.LegacyThreadSetupActionWrapper$1.call(LegacyThreadSetupActionWrapper.java:44) at io.undertow.servlet.api.LegacyThreadSetupActionWrapper$1.call(LegacyThreadSetupActionWrapper.java:44) at io.undertow.servlet.api.LegacyThreadSetupActionWrapper$1.call(LegacyThreadSetupActionWrapper.java:44) at io.undertow.servlet.handlers.ServletInitialHandler.dispatchRequest(ServletInitialHandler.java:272) at io.undertow.servlet.handlers.ServletInitialHandler.access$000(ServletInitialHandler.java:81) at io.undertow.servlet.handlers.ServletInitialHandler$1.handleRequest(ServletInitialHandler.java:104) at io.undertow.server.Connectors.executeRootHandler(Connectors.java:202) at io.undertow.server.HttpServerExchange$1.run(HttpServerExchange.java:805) at java.util.concurrent.ThreadPoolExecutor.runWorker(ThreadPoolExecutor.java:1142) at java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoolExecutor.java:617) at java.lang.Thread.run(Thread.java:745)
Dit is bij nog sommige website zoals web.whatsapp.com .
Als ik via google gewoon "Bol" zoek dan kan ik wel via het eerste zoekresultaat gewoon op de site.
Deze fout heb ik via elk apparaat via eender welke router/switch in huis.
Via telefonische techsupport kunnen ze precies enkel de modem herstarten dus daar heb ik helaas 40min aan kwijt gespeeld, op twitter of messenger krijg ik geen antwoord.
Sinds enkele dagen heb ik ook mijn 750GB in de piekuren bereikt dus zit nu op smallband, normaal gezien wordt je 1x omgeleid naar een Telenet pagina die je daarvoor waarschuuwt. Nu denk ik dat het die pagina is waar ik naartoe word gestuurd die die stack trace geeft, op die manier kan ik nooit op de knop duwen en zeggen dat ik ervan op de hoogte ben dat ik intensieve gebruiker ben.
Nu heb ik nog wat zitten rondneuzen en ik kan precies niet pingen naar het ip (185.14.169.113) van bol.com (100% packetloss), ik weet zelf niet veel van netwerken dus deze info kan volledig onnuttig zijn.
Tegenwoordig werken we allemaal van thuis uit dus dit is redelijk hatelijk als de helft van de links waarop je klikt niet werken, zeker als developper moet je vaak verschillende sites bezoeken voor een bug te fixen 😕
Echt alle hulp is welkom!
6 reacties
@ArthurJ
Een ping naar bol.com geeft bij mij exact hetzelfde resultaat, Dat op zichzelf heeft dus alvast niks met uw specifieke situatie te maken.
EDIT: bol.com rechtstreeks in de adresbalk invoeren geeft wel een juist resultaat bij mij.
Geef eens  https://www.bol.com/nl/ in uw adresbalk. Werkt dat wel?
@ArthurJ welke browser gebruik je, kan een fout zijn in de browser instellingen bv.
hier geen enkele fout met safari op MacBook.
ArthurJ
Ik heb deze fout op mijn iphone, macbook en pc en mijn moeder haar iphone, ipad en pc.
Ik denk ook niet dat het de browser is aangezien het een stacktrace is van Telenet zelf.
Arnie
De naam van de redirect url "fup_redirect.html" doet wel sterk vermoeden dat dit veroorzaakt wordt door het overschreiden van de Fair Use Policy.
Waarschijnlijk is deze redirect pagina in de cache van je device opgeslagen. Probeer eens een reload (bij PC is dit ctrl-F5, ik weet niet wat dit bij appel is), of het wissen van de cache.
Misschien doet Telenet ook wel iets op DNS vlak, dat ze de gevraagde hostname via DNS aan een ander ip adres koppelen, om je zou op de telenet server om te leiden, zodat je deze fout te zien krijgt. Misschien eens een uurtje wachten, dan zal deze DNS etnry wel expired zijn.
   Arnie | Krak
ArthurJ
DNS is inderdaad het eerste waar ik aan dacht, maar heb handmatig geswitched naar 1.1.1.1 en 8.8.8.8 zonder success.
Ctrl + F5 heeft ook helaas geen zin gehad.
Heb ook ontdekt dat mijn vermoeden correct was: het is wel degelijk de melding van de Telemeter.
Overmorgen heb ik een nieuwe pod, dus het zal gewoon wachten zijn.
Het zou ook kunnen omdat ik nu door mijn nieuwe modem een nieuw IP heb dat er intern bij Telenet iets fout loopt. achja 2 daagjes wachten en dan hopen dat het weg is.
ArthurJ
Hier zijn 2 oplossingen:
1: Als ge uw limiet van 750GB bereikt hebt in de maand, verander dan zeker niet van modem in diezelfde maand, de Telenet backend vindt dat absoluut niet plezant met de verandering van uw IP enzo.
2: Telenet fixt hun code(de stacktrace is er) en deze edgecase valt nooit meer voor.
