phrs
Device that converts coax signal into RJ45 jack?
My apartment in Schaerbeek gets internet from a Telenet coax cable that first feeds into a (powered) device NIU-65/88-GA-01A-BE05.
The device features several output ports; one of them goes into the Telenet WiFi router of my home network.
The apartment is entirely wired with coax cables with a socket in every room--I suppose it was the dominant technology at the time (2007 or thereabout).
Is there a device that would convert the coax signal onto an RJ45 ethernet jack? Something I could plug into the existing coax socket to have a wired connection wherever needed?
Titre modifié par Filip (mod) | Titre précédent : NIU-65/88-GA-01A-BE05
2 reacties
Philippe_
Moderator
Lezersgoud. Respect! Een bus vol! Topicvreter! Warming up?
@phrs
I've moved your topic to the NL section of this community, as it was originally in English. Hopefully, someone here will be able to assist you. 🙂
https://www.netweters.be/html/assets/Telenet%20logo%20signatures.pngPhilippe
Moderator
A MoCA adapter puts an internet connection on the coax cable & another MoCA adapter is able to extract it into ethernet again.
Some of the other members of De Netweters have used it & should be able to give some assitance
