26.678
is dat probleem ook met een pc op wifi ?
je kan ook is thetering proberen ( geeft ook een ander resultaat )
kan je is zien of het op 5G en 2.4G hetzelfde probleem is ?
het kan zijn dat het op 5G beter gaat ( of slechter )
mvg
PowerChaos
blijkbaar toch nexus probleem
hier is een quote van een post met een oplossing
How to Fix Android 7.0 Wi-Fi Problems
Surprise, surprise. Some Nexus owners are running into Android 7.0 Nougat Wi-Fi problems. This actually isn’t much of a surprise given that Wi-Fi problems are among the most common issues for phones and tablets.
If you’re running into a Wi-Fi issue while on Nougat, the first thing to do is check your router. We recommend unplugging your router for a solid minute before plugging it back in to see if that helps resolve your issue.
If you can’t do this because you’re in a public place or if you’re positive it’s not a router issue, try these fixes.
First, you’ll want to go in and forget the Wi-Fi network giving you problems. Head into your Wi-Fi settings, either in the Settings menu or via Quick Settings and select the desired Wi-Fi connection. Choose Forget (this will make your device forget the password so make sure you know it) and then reconnect to see if the connection improves.
If that doesn’t help, we recommend updating your applications. And if that still doesn’t help dislodge your Wi-Fi issue, you’ll want to boot your Nexus device into Safe Mode in an effort to single out problem apps. Apps have been known to cause issues with connectivity and they could be causing the problem on your device.
edit
hier is nog een oplossing ( rare oplossing )
Yeah I saw that too and since I was having the dog slow wifi problem I tried it and it worked! I was surprised.Read on another site - but for some reason when my wifi is slow, turning on BT makes it move fast
It seems to be an incompatiblity problem with some router's radios. I put up a second access point and my 5x connects to that without issue. The primary router's wifi is always slow, like dial up slow.
Anyway enabling Bluetooth does fix it for me.
mvg
PowerChaos
het laatste dat je kan proberen maar wat ik eigenlijk afraad is het volgende
een downgrade
hier vind je info over
https://www.androidpit.com/how-to-downgrade-a-nexus
maar als je toch die weg wilt opgaan kan je beter hier zoeken naar een custom rom
http://www.xda-developers.com/
lg nexus 5x
http://forum.xda-developers.com/nexus-5x/development/rom-debloated-busybox-fast-stable-t3398617
maar nog is , ik raad dit niet echt aan omdat het je telefoon helemaal kapot kan maken ( bricked zoals ze zeggen )
en daar bedoel ik dus het volgende mee
bootloader struck , unable to boot , unable to power on , boot loop ( opstarten en direct restarten ) unable to find the phone back , unable to get out of recovery en nçg een hoop zaken
dus voordat je deze oplossing probeerd moet je er rekening mee houden dat het de laatste oplossing is
Garantie van de telefoon kan hierdoor ook weg gaan
Zeker alles goed nalezen wat je moet doen , want anders kan er veel kapot gaan
mvg
PowerChaos
