27.170
As our homes become more filled with Wi-Fi demanding devices, the near necessity of a mesh network is slowly becoming unavoidable. For now though, mesh Wi-Fi systems are premium products that demand a premium price, and Nest Wifi is no different.
If the Google Assistant is your home voice AI of choice, you have two solid choices to review: 2017’s Google Wifi and the new Nest Wifi. Yes, despite the Nest Wifi being poised as the clear successor and replacement to the Google Wifi, both products are still available for purchase for the time being.
That fact is further complicated by Google Wifi having a nearly identical feature set — minus the smart speaker capabilities — and a reduced price tag. In fact, you can currently purchase a Google Wifi three-pack for less than a Nest Wifi two-pack. The older system does require a slightly more difficult setup and management process, if only that you may need the separate Google Wifi app for certain tasks.
Unless you have a specific desire to put a Google Assistant smart speaker in the exact same place that you would put a mesh Wi-Fi point, it’s hard to justify the Nest Wifi’s current pricing. On the flip side though, Marie Kondo would probably be proud of Google’s effort to fold two disparate everyday devices into one form.
That said, on the whole, I thoroughly enjoyed having the Nest Wifi system during my review period and I can strongly recommend it to any networking novices for its ease of setup and wildly impressive audio quality.
Edit door @Suzy (20/01 om 12:10)
Het punt is dat we vele toepassingen via wifi in huis hebben, en dat we door de miserable telenet router die niet goed kunnen ondersteunen, en een extra wifi router er bij moeten kopen.
weer een 2 a 300 ballen onnodig, daar Telenet zegt dat 75% of meer geen wifi gebruikt...
Dus de oplossing is Telenet geef ons een router die ook wifi goed ondersteunt...
300 Mbps draad en 50 Mbps wifi is toch te gek om lost telopen...
@amj De core business van een provider is goed internet aanbieden en niet Wifi. Net zoals een electriciteitsverkoper electriciteit verkoopt en de installatie in je huis uw verantwoordelijkheid is.
Bovendien is WiFi zeer beperkt in mogelijkheden ondanks als hoera berichten in sommige reklames. Muren, afstand, Led transo's, dampkappen, microgolfovens, dect telefoons enz. allemaal storende invloeden. En je zal misschien 10% winst hebben als je een andere router op exact dezelfde plaats zou zetten als deze van Telenet. Conclusie Wifi is net als goede bekabeling je eigen verantwoordelijkheid afhankelijk van je eigen specifieke situatie.
Mijn abonnement wordt door Telenet verkocht voor 150 Mbps donwload en 15 Mbps upload. In de ruimte waar ik rechtstreeks verbinding kan maken met de HGW van Telenet haal ik via wifi een snelheid van meer dan 140 Mbps download en meer dan 14 upload.
In een andere ruimte waar ik het doe met de Wifi powerline van Telenet heb ik nu de wifi test gedaan en de snelheden zijn respectivelijk 93,2 en 14,4 Mbps. Ik merk geen verschil in snelheid tussen verbinding met utp en de wifi verbinding op 5 GHz. Met de 2,4 GHz haal ik een lagere snelheid. Test met smartphone 84,5 en 14,3 Mbps. Met tablet 92,4 en 14,1 Mbps.
Indien uw Wifi snelheden zo laag zijn, is er mogelijk een andere oorzaak.
Hey,
als ik echter naar mijn WFA kijk, dan lees ik: 150mbps bij 300 mbps telenet (downstairs)
shalom
@amj schreef:
Hey,
shalom
Dat is uw maximale snelheid. Als je eerlijk bent lees je ook dit en houd je daar ook rekening mee
Trouwens waar haal je uw bewering dat "daar Telenet zegt dat 75% of meer geen wifi gebruikt."
Ik neem aan dat je bedoelde dat "Telenet zegt dat 75% of meer wel wifi gebruikt".
@amj ik heb daarnet de URL's naar de webshops in je topic verwijderd, want reclame maken is niet toegestaan op De Netweters.
Tip! Volgende keer wanneer je een copy-paste doet van een externe bron, is het best om dit te vermelden en vervolgens ook de URL naar je bron te delen. Nu lijkt het namelijk alsof je deze tekst zelf hebt geschreven en de "review" zelf hebt gedaan. Daarnaast kaderde dit topic niet waar je vraag over ging en wordt het voor andere Netweters moeilijker om je te helpen. 😉
200 à 300 euro voor een router? Wie heeft je dat aangeraden?
lulkoek
Nee het is de gewoon de Telenet router, door Telenet Tech bevestigd
De antwoorden zijn niet mijn data maar van Telenet Techno...
groetjes
oops foutje, de bedoeling was om aan te tonen dat er ook andere wegen zijn die naar Rome verwijzen, get my drift, Suzy.
Als je wel eens op de sites kijkt bijv. Tigerbytes of andere Webwereld of zo, zou je niet zulke antwoorden geven....
